2004 Chevy Impala traction control system indication
70,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVIDJS
at random times but mostly when backing out of driveways then shifting from reverse to drive, the abs light and the service traction control system lites come on also the abs system comes on and i can hear the motor turning on..i've been told this may be a fuse issue so i checked them. found 1 that needed replacement..no difference. help? cant afford to take to a shop right now. any advice would be greatly appreciated...
Oct 13, 2009 at 4:21 AM
RHALL77
  • 3,361 POSTS
stop at your local auto zone or something similar and see if they can scan your abs system. sounds like you may have a bad wheel sensor. let me know what you find out and ill see what i can do to help
Oct 13, 2009 at 9:54 AM
