2004 Chevy Impala Traction Control Light
144,000 MILES • 6 CYL • FWD • AUTOMATIC
AJANDMELIJ23
I was riding down the road in my 2004 Chevrolet Impala LS and suddenly my traction control light, brake light and low brake fluid level came on all at once. I checked the brake fluid level and it is full. What do you think is wrong?
Oct 29, 2008 at 2:43 PM
IMPALA04IMPALA
I just had the exact same problem on my '04 Impala and I came across your post. It turned out to be a defective float in the brake fluid resevoir. Apparently it sunk and tripped the 'low brake fluid' light which also triggered the 'trac off' and 'brake' lights. I had the resevoir replaced and the problem is gone. The GM part number is 18023763. I hope this helps.
Nov 21, 2008 at 12:04 PM
