2004 Chevy Impala Traction Control Light
AJANDMELIJ23
  • 2004 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 144,000 MILES
I was riding down the road in my 2004 Chevrolet Impala LS and suddenly my traction control light, brake light and low brake fluid level came on all at once. I checked the brake fluid level and it is full. What do you think is wrong?
Wednesday, October 29th, 2008 AT 9:43 PM
IMPALA04IMPALA
I just had the exact same problem on my '04 Impala and I came across your post. It turned out to be a defective float in the brake fluid resevoir. Apparently it sunk and tripped the 'low brake fluid' light which also triggered the 'trac off' and 'brake' lights. I had the resevoir replaced and the problem is gone. The GM part number is 18023763. I hope this helps.
Friday, November 21st, 2008 AT 8:04 PM
