2004 Chevy Impala tie rod
42,349 MILES • 6 CYL • FWD • AUTOMATIC
JOELZAK
  • 19 POSTS
Need to replace the tie rod.(the rod itself)
How do i remove the tie rod?
The new one is flattened for a crows foot to get around it
The stock tie rod is not flattened for a crows foot.
So what do i use to remove the inner tie rod with?
Feb 6, 2009 at 3:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need a tie rod puller..Procedures are below for removal and replacement..
REMOVAL:
Raise and safely support the vehicle.
The outer tie rod ends may be retained to the steering knuckle by either a slotted nut and cotter pin or a torque-prevailing nut. If a slotted nut and cotter pin is used, remove and discard the cotter pin and remove the slotted nut.
If a torque prevailing nut is used, remove the nut from the tie rod end's ball stud at the wheel knuckle. GM specifies that this torque prevailing nut be discarded and a new torque prevailing nut be used at assembly. Most service replacement tie rod ends come with new hardware.
The position of the tie rod ends determines the toe angle of the steering alignment. To get the replacement tie rod end positioned as closely as possible to the original tie rod end's position, the jam nut's position should be marked. Some technicians, after thoroughly wire-brushing the jam nut and the inner tie rod shaft threads, will mark one flat of the jam nut with paint. Then, the jam nut is loosened exactly one turn.
Remove the tie rod end from the wheel knuckle. GM says that the tapered joint of the ball stud has been designed to separate easily, unlike previous joints of this type. If required, use a tie rod puller to separate the tie rod end from the wheel knuckle.
Unscrew the tie rod end from the inner tie rod shaft. Do not disturb the jam nut. It should have been loosened one turn only from its original position.
INSTALLATION:
Clean all parts well. Make sure mating surfaces of the stud and knuckle are clean.
Thread the replacement tie rod end onto the inner tie rod shaft until it just touches the jam nut. Loosen the tie rod end exactly one turn.
Install the tie rod end ball stud to the wheel knuckle. If equipped with a torque prevailing nut, tighten to 18 ft. lbs. (25 Nm). Tighten the nut an additional 180 degrees (one-half turn). If equipped with a slotted nut for a cotter pin, tighten the retaining nut to 45 ft. lbs. (60 Nm) maximum to align the cotter pin slot. DO NOT back off (loosen) the nut to align the slots in the nut with the cotter pin hole in the ball stud. Install a new cotter pin.
Turn the jam nut one turn. This should tighten the jam nut against the end of the tie rod threaded portion. Tighten the jam nut to 50 ft. lbs. (68 Nm).
Check that the rubber rack and pinion dust boot is not twisted or puckered.
Have a front end alignment performed at a qualified shop.
Thanks for using 2CarPros.com!
Feb 6, 2009 at 3:34 PM
JOELZAK
  • 19 POSTS
Thanks for explaining how to replace the outer tie rod end.But i got that down, its the inner tie rod.
The rod itself is bent and its got to go.
So when i removed the boot,I realized that the housing wasnt flattened at all for any crows foot.It is perfectly round so anyone have any suggestions how or what I need to use to unscrew that bugger off.
Thank you
Feb 6, 2009 at 8:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, sorry about that. Below are the inner tie rod removal instructions. If you still have problems just let me know..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_223.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_68.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_40.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname4_24.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname5_12.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname6_7.jpg
FIGURE 88
https://images.2carpros.com/forum/automotive_pictures/261618_88_1.jpg
FIGURE 89
https://images.2carpros.com/forum/automotive_pictures/261618_89_1.jpg
FIGURE 90
https://images.2carpros.com/forum/automotive_pictures/261618_90_1.jpg
FIGURE 91
https://images.2carpros.com/forum/automotive_pictures/261618_91_1.jpg
FIGURE 92
https://images.2carpros.com/forum/automotive_pictures/261618_92_1.jpg
FIGURE 93
https://images.2carpros.com/forum/automotive_pictures/261618_93_1.jpg
FIGURE 94
https://images.2carpros.com/forum/automotive_pictures/261618_94_1.jpg
FIGURE 95
https://images.2carpros.com/forum/automotive_pictures/261618_95_1.jpg
SPECIAL TOOLS
https://images.2carpros.com/forum/automotive_pictures/261618_t_1.jpg
Feb 7, 2009 at 10:22 AM
JOELZAK
  • 19 POSTS
Bluelightnin6 you have been big help.
This is my first inner tie rod replacement and am not too familar with staking are there staking tools to make this job easier or any tips?
And again thanks for the info you couldnt have been more clearer.
Feb 7, 2009 at 6:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need a hammer and punch. Make sure to use a wooden block to support the opposite side of the rack and inner tie-rod end while staking. (pictured below)
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_225.jpg
Feb 7, 2009 at 6:36 PM
JOELZAK
  • 19 POSTS
Here is a picture of the inner tie rod housing. In thew instructions you gave me the wrench will work on the new housing that i have but will not on the stock housing. Look at this picture and get back to me on what tool i use on the stock inner tie rod housing:
https://images.2carpros.com/forum/automotive_pictures/311287_inner_housing_tie_rod_green_1.jpg
https://images.2carpros.com/forum/automotive_pictures/311287_inner_housing_tie_rod_green1_1.jpg
Feb 14, 2009 at 8:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Once the lock nut is backed off and the tie rod is disconnected from the steering arm, hook the ring spanner over the threaded end. Then turn it off.
Feb 14, 2009 at 10:04 AM
ANNF14
Hello all you have to do is remove that outer coating (plastic) and the tool just slide right in if you have the apropriate size.
Feb 14, 2009 at 10:09 AM
JOELZAK
  • 19 POSTS
Since i will be staking with everything installed in the car.
Should i worry about supporting or just stake it?
If supporting is a must any suggestions how with a limited amount of room.
Feb 17, 2009 at 5:35 PM
JOELZAK
  • 19 POSTS
ok im about ready to do my first inner tie rod and everyone has been big help.
Now im worried about staking my housing with it installed in the car.
How do you suggest i support it from being damaged while staking?
Any tricks,or is it cool to just stake it?
Not much room for anything.
Feb 19, 2009 at 4:39 PM
JOELZAK
  • 19 POSTS
should i be concerned with staking my housing on my inner tie rod while it is installed in the car, and if so what tricks or technique do i use to keep from damaging anything. thanks for the help
Feb 19, 2009 at 7:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First check to see if the rods are equipped with holes to do the staking in the first place. If it does, then just support the rack while you're staking.
Feb 20, 2009 at 1:55 PM
JOELZAK
  • 19 POSTS
You have helped me more than you know.And if i had it i would donate.Thank you
Feb 27, 2009 at 2:16 PM
KASSI411
The tires on the front of my car feel like they were going to fall off. I had it checked by 2 different shops and they both said I needed a tie rod on the right side and bearings and ball joints on both. I recently had all of that replaced (within the last 2 months) and I still have the same problem. It starts at about 30 miles per hour and has a lot of vibration and feels like the tires are going to fall off and stops when I get to about 60 miles per hour. I also had the struts replaced last year.
Any suggestions as to why I'm still having this problem?
Oct 23, 2018 at 9:35 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
If front end solid and all the work was done
I would suspect and check tires
have them balanced
Check it for alignment
JOELZAK
  • 19 POSTS
ok i got the outer tie rod end off not a problem.
Now when i exposed the inner tie rod by removing the boot I noticed that it is not flattened for a crows foot or any other wrench to spin it free.
I have to be missing something can you tell me what the heck i need to use or do to pull that bent rod out.
Thank you guys
  • 31,937 POSTS
HI there,
with the lock nut backed off and the tie rod disconnected from the steering arm, just hook the ring spanner over the threaded end and wind it off, when it stats to move it should be finger tight anyway.
mark (mhpautos)
