2004 Chevy Impala spark plugs
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
396KIM
What is best way to access the fireweall side spark plugs to change and replace with new ones. Cannot reach these plugs from below and seems like I will have to remove components to access from the top side.
May 14, 2008 at 11:03 AM
MASTERTECHTIM
  • 4,750 POSTS
i use a swivel spark plug socket with a extension from the top. also if it has a front engine dog mount you can undo it and use a strap tie down and pull engine forward.
May 14, 2008 at 11:08 AM
