2004 Chevy Impala Power Steering Leak
162,000 MILES • 6 CYL • 2WD • AUTOMATIC
WPINEDA
I found the leak on my car, is on a aluminum line that runs under all the belts by the front right tire. Now what i need to know is if i can fix it? Or do I need to replace? It is leaking power steering fluid when i turn the wheel, it's a real fine squirt. Is not a big leak and if i have to replace it, can you send me a diagram of the hole line
Aug 10, 2009 at 2:28 PM
BMRFIXIT
  • 19,053 POSTS
Its a high pressure line and need to be replaced
Aug 10, 2009 at 11:04 PM
