2004 Chevy Impala passlock
120,000 MILES • 6 CYL • FWD • AUTOMATIC
TWO6STRINGS
about once a week, my car is dead when i turn the key, will not crank. I let it set 10 minutes...and it works, heard/read its something to do with the passlock system.
how do i change this out without making GM rich, is there a bypass system I can install easily? I really want a fix that works for this. not just a bandaid. ps...if I get info from you guys that really works, I'll gladly dontate...I'm not cheap.
Ken
Sep 22, 2008 at 4:54 AM
RHALL77
  • 3,361 POSTS
i would highly suggest not bypassing the system. Basically removing the lock cylinder is the way to replace the pass lock sensor. it is part of it. i can help you out if you want more info.
Sep 22, 2008 at 9:05 AM
