2004 Chevy Impala heat
60,000 MILES • 6 CYL • FWD • AUTOMATIC
ROCKYTRENT
when i start car never get any heat but gauge shows temp normal, just like cool air coming thru vents but start driving and will get heat
Jan 22, 2008 at 1:43 PM
BMRFIXIT
  • 19,053 POSTS
[quote:37043da03b="rockytrent"]Heater problem
2004 Chevy Impala 6 cyl Front Wheel Drive Automatic 60000 miles
when i start car never get any heat but gauge shows temp normal, just like cool air coming thru vents but start driving and will get heat[/quote:37043da03b]
check coolant and add if needed
check heater core hoses
if one hot and the other not
flush heater core
check water pump operation
Jan 23, 2008 at 10:30 AM
DENNYP
  • 1,824 POSTS
There is a bad problem with theese cars getting air in the heater core. raise the front of the vehicle and add some coolant. This might get some of the air out. You might also have to use a vacuum fill tool to get the air out.
Jan 23, 2008 at 1:48 PM
