2004 Chevy Impala FRONT DRIVER SIDE WHEEL
10,437 MILES • 6 CYL • FWD • AUTOMATIC
LAKOTACOWBOY
I had slide on ice into a the sidewalk curb and since then the steering wheel vibrates when i go down the road i had also notice the rim on the tire was bent inn a little bit can you tell me what can be wrong and how i can repair it and how much it would possibly cost in repairs.
Apr 2, 2008 at 8:27 AM
BLACKOP555
  • 10,386 POSTS
First look at the front end, do the tires look parallel? if so jack up the end that hit and shake it and pull on it, feel for looseness, if its loose then the wheel bearing is probably bad, check the tie rods and ball joints also.
Apr 2, 2008 at 1:10 PM
