2004 Chevy Impala engine will not turn over
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEBRADENISE
diagnostic code read catalyst conveter and crank shaft sensor my car will not start
Mar 30, 2010 at 4:36 PM
  • 75,988 POSTS
1st check and test the crankshaft position sensor and then do a backpressure test on the exhaust system to rule out the Cat
Mar 30, 2010 at 4:47 PM
DEBRADENISE
how do i check back pressure ?
Mar 30, 2010 at 5:15 PM
  • 75,988 POSTS
Thru the oxygen sensor by a pressure gauge or disconnect the exhaust pipe on the exhaust manifold.
Could be a problem with the oxygen sensor/s or the Cat itself
Mar 31, 2010 at 8:52 AM
