2004 Chevy Impala engine will not turn over
DEBRADENISE
  • 2004 CHEVROLET IMPALA
  • 6 CYL
  • 40,000 MILES
Diagnostic code read catalyst conveter and crank shaft sensor my car will not start
Tuesday, March 30th, 2010 AT 11:36 PM
1st check and test the crankshaft position sensor and then do a backpressure test on the exhaust system to rule out the Cat
Tuesday, March 30th, 2010 AT 11:47 PM
DEBRADENISE
How do I check back pressure?
Wednesday, March 31st, 2010 AT 12:15 AM
Thru the oxygen sensor by a pressure gauge or disconnect the exhaust pipe on the exhaust manifold.
Could be a problem with the oxygen sensor/s or the Cat itself
Wednesday, March 31st, 2010 AT 3:52 PM
