2004 Chevy Impala engine cooling is leaking
MALDEN
Engine Cooling problem
2004 Chevy Impala 6 cyl Front Wheel Drive Automatic
my engine cooling leaking and my car run hot with can i do to stop it
Oct 25, 2009 at 11:24 AM
  • 31,937 POSTS
Hi there,
The first thing you must do is have the cooling system pressure tested, this will locate any external leaks, when that is done and you have located the leaks, re post your findings for more advice on what to do.
Mark (mhpautos)
Oct 25, 2009 at 12:28 PM
SERVICE WRITER
  • 9,123 POSTS
These motors had a common problem of intake manifold gaskets going bad. You may or may not have this condition.
The first thing you need to do is locate the leak. Visually look on the motor above the coolant puddle. Sometimes pressure testing the system makes it easier.
Don't blow your engine, find it.
