2004 Chevy Impala Delayed Start
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
MELISSAFIONA
I have a 2004 chevy impala. My car has a delay in starting up. Sometimes it starts up right away and other times it can take up to 15 minutes and many tries before it starts up. When i try to turn the car on everything else works but the engine, the radio, lights, locks comes on as intended-so i dont think it has anything to do with the battery. Also, when i attempt to start the car, it does not make any harsh noises-it just sounds like air and then a rolling sound. Recently my gas guage has started to read incorrectly-i cant tell if i have a full tank or not. I dont know if this has anything to do with the car not starting. Please give me your advise...Thank you.
Jan 22, 2009 at 5:43 AM
  • 75,988 POSTS
Next time it refuses to start duplicate the problem and do below
Get a starting fluid or ether and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jan 22, 2009 at 5:52 AM
