I ran my car through the car wash last night and this morning the heater will not blow out any air at all. I checked the fuses and they are fine.
Feb 5, 2009 at 1:47 AM
RHALL77
✓Experienced Mechanic
check your blower motor and make sure you are getting voltage to the motor. try tapping on it with the end of a screw driver and see if it will start working. you may also need a blower resistor depending on the problem
