2004 Chevy Impala BCM Module or Instrument Cluster?
176,000 MILES • 6 CYL • FWD • AUTOMATIC
ATL252006
I have a 04 impala. After installing a aftermarket cd player in the car, my dashboard lights stop working. The illuminator which allows me to see how fast i'm driving at night, and the part that allows me to select the a/c heat doesn't illuminate. The interior dome lights work, and the cruise control, check engine lights come on. Is that the sign of a bad BCM? I checked all the fuses and no fuses are blown. OR do you think I need a whole new instrument cluster, my cluster does stick from time to time and doesn't read the right speed/temp.
Thanks
Aug 23, 2009 at 9:55 PM
DOCFIXIT
  • 18,828 POSTS
Did you use an adapter from player to existing car radio plug?
Aug 24, 2009 at 3:28 AM
