2004 Chevy Impala 2004 CHEVROLET IMPALA SS
100,000 MILES • 6 CYL • FWD • AUTOMATIC
NICOL_I_NICOL
Sorry, it's about 2004 Chevrolet Impala SS.
I replaced the left and right wheel hub and ABS pump but I still have the code U1040. How can I fix?
Aug 21, 2009 at 11:04 PM
MERLIN2021
  • 17,250 POSTS
U1040 isnt a code for wheel sensors or pump, it's a communication problem between the brake module and the rest or the modules, try inspecting the plug at the brake module. It's on left rear (drivers) side on ABS hydraulic modulator. Look for water intrusion, or bent or pushed out pins...broken wires! Check fuses! Under the hood there is a fuse box as well as in the car, look for all that refer to ABS or EBCM.
Aug 21, 2009 at 11:19 PM
