White smoke from exhaust?
119,000 MILES • 6 CYL • 4WD • AUTOMATIC
WHITAKEC
My car has recently started blowing white smoke out the exhaust,and drags up a hill.
Jun 8, 2010 at 12:01 AM
SEVAG P
  • 405 POSTS
hi,
White smoke usually appears from burning coolant, as a first step check the coolant level if the level is low then check the link below.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
If the smoke is dark white more like blue color its from engine is burning oil, as a first step check the oil level excessive oil can enter into the combustion chamber and burn. also check the oil quality if its too old no proper viscosity.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
let us know what happens with you.
thank you.
Jan 16, 2021 at 6:30 AM
