2003 Chevy Impala water leak
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
MANDY26
I have a leak from somewhere under the hose and pipe (with the small bolt on top) that runs to the radiator cap area. it leaks directly onto the fan belts spraying water everywhere and makes a whistling sound. As quick as the water is poured into the radiator it is running onto the ground just as quick. What part would you sugggest is leaking?
Oct 7, 2009 at 6:40 AM
RHALL77
  • 3,361 POSTS
pressure test it and see if it is coming from metal or rubber. sounds like a bad hose or a bad o ring. let me know what you find and ill see what i can do to help
Oct 7, 2009 at 10:27 AM
