2003 Chevy Impala Turn Signal
2003 CHEVROLET IMPALA
ACCELLENT
Electrical problem
2003 Chevy Impala 6 cyl Two Wheel Drive Automatic
My right front turn signal is not working. The bulb is fine. The rear turn signal flashes very rapidly and the turn signal light in the car is not showing I have the right turn signal turned on.
Nov 27, 2008 at 5:00 AM
  • 110,244 POSTS
Hi:
If you are sure that the bulb is good (tested), there are two things that could cause this. First is the light socket itself. It may no longer be making proper connection with the bulb. Check it and make sure it's clean, free of corrosion, and not damaged. If it appears in good condition, use a test light to check for power to it with the signal on.
Let me know what you find.
Dec 1, 2008 at 5:18 AM
