when my car is cold the transmission slipps but when it warms up it stops, then about a month ago while i was driving i notice the transmission slipping and my engine begin idleing rough, so i pulled over shut off the engine and restarted the engine and all the symtoms stopped the engine begin to idleing smoothly and the transmission stop slipply, the car was running smoothly for a while then recently the same thing happened so again i restarted the engine but this time the engine light came on and the engine ran rough and the transmission began to slipping between gears. I'am not sure if my transmission is going out or if i have some sort of sensor or electrical problem, has anybody else had this problem or advice about what the problem could be?
May 23, 2010 at 7:19 PM
