2003 Chevy Impala Starting
88,000 MILES • 6 CYL • FWD • AUTOMATIC
REDIMPALA
Just lately my Chevy Impala will not crank when trying to start the engine. Nothing happens! There are no clicking sounds from the starter or the engine itself. After a few attempts to start the engine, I wait a few minutes and it will start and run perfect. Could this an electrical problem?
Apr 13, 2009 at 8:22 AM
RENAUDTN
  • 636 POSTS
It sounds like a passlock problem. Passlock is your theft deterrent device. If something is wrong with it, your BCM will either lock the starter or the fuel injectors. You should see your security light either blinking or steady on on the dashboard. A lot of time, this problem is associated with a defective passlock sensor; but it could be several other things as well, including a worn ignition lock cylinder, bad connection to the BCM, or bad BCM altogether. A trip to a Chevy dealer is recommended for an accurate diagnostic.
Apr 14, 2009 at 4:31 AM
