2003 Chevy Impala periodically rough shifting
PHOENYX987
Transmission problem
2003 Chevy Impala 6 cyl Front Wheel Drive Automatic
sometimes my tranny will slip when taking off from a stop. Also it will occasionally start shifting hard all the time then goes away. I have already changed fluid and filter. What's going on?
Feb 10, 2010 at 9:18 AM
  • 110,248 POSTS
It sounds like the trans control module. Has the check engine light come on? How many miles are on the vehicle?
Feb 23, 2010 at 12:45 AM
PHOENYX987
Thank you for answering my email, the check engine has not come on and there is a 100,000 on the vehicle.
Mar 4, 2010 at 5:56 AM
  • 110,248 POSTS
Based on your description, I recommend having the trans control module checked. It is what controls the trans. My only concern is the slipping on occation. At 100K I wouldn't expect the trans to be bad, but it does happen.
Mar 4, 2010 at 10:22 PM
GUNKIE
my 04 impala does the same kinda slams into gears when it warmed up
Apr 30, 2010 at 8:36 AM
  • 110,248 POSTS
Has the check engine light ever come on?
May 1, 2010 at 6:17 AM
