2003 Chevy Impala P1811 Maximum Adapt and Long Shift
2003 CHEVROLET IMPALA
44,000 MILES • 6 CYL • FWD • AUTOMATIC
BISCEGB
I was told I need a Pressure Control Solenoid. I was wondering where this is located and if when changing it does the transmission fluid have to come out or do I need to pay for a flush?
Jan 12, 2009 at 7:42 AM
BRIAN 1
  • 1,030 POSTS
the pc solenoid is located inside the trans,you have to drop the cradle down and remove the side cover on the trans to replace it. usually takes 8-10 hrs,these take alot to replace.you will loose some fluid replacing it,but you can top it off when your done.you don't have to flush it but it would be a good idea.post back with any other questions.
Jan 12, 2009 at 10:27 AM
