2003 Chevy Impala Nobody can find problem!
68,000 MILES • 6 CYL • FWD • AUTOMATIC
DAJN
Car has had a wiggle(bouncing?) in front end since I drove it off the used car lot. Car dealer and I between the two of us have replaced all 4 struts, both front axles and front wheel bearings, brakes and rotors all the way around, new tires, replaced rear sway bar hardware and an alignment. What's left that could be causing this? Every garage that has looked at said that they see or feel nothing loose or irregular, I'm about too just give up and just drive it with it riding horribly!
Apr 19, 2009 at 2:45 AM
DOCFIXIT
  • 18,828 POSTS
Try running a CARFAX on it and see it was in a wreck.
If so body maybe out of true
Apr 19, 2009 at 8:37 AM
TAKECHARGESARGE
  • 92 POSTS
Has anyone tried putting a different set of wheels on this car? It sounds to me as if one of the rims/wheels was bent somehow.
TakeChargeSarge
Jul 29, 2009 at 4:00 PM
