Electrical problem 6 cyl Two Wheel Drive Automatic
this vehicles climate control will not come on, the blower motor is not working,the a/c button doesn't light up when pressed.i found that in the fuse block on the drivers side of the dash that the blower motor fuse has no power. if i supply that fuse with power then everything works normally.all other fuses are good. my main question is,where does this fuse receive power from. thank you for your help in advance.
Aug 4, 2010 at 5:04 AM
