2003 Chevy Impala lower control arm/ISS
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
JTELLES
  • 9 POSTS
I replaced the ISS and the clunk noise is still there, I checked the front lower control arm bushing and it's got a cut on the rubber. Will this make my car make the clunk noise and or the stabilizer bar links?
Aug 13, 2009 at 3:13 AM
BMRFIXIT
  • 19,053 POSTS
Lower control arm bushing is very common failure
need to be replaced
Aug 15, 2009 at 12:10 AM
JTELLES
  • 9 POSTS
I already replaced, lower control arm bushings, strut mounts/bearings, barlinks, rack and pinion etc. I'm running out of ideas. I can only think on lowering the subframe to see if they are any crack on it. I was told that some impalas subframes were not welded the proper way. Is it possible?
Aug 18, 2009 at 2:19 AM
