2003 Chevy Impala leakage
97,870 MILES • 6 CYL • FWD • AUTOMATIC
SHEOCKI
i hit a pot while drive and later found that my powersteering fluid is leakage for an u-shaped metal piece front the front lower part of the car. i went to the auto store an the clerk told me not to buy the stop leak because it would be a waste of time-however my neighbor said it is not the powersteering pump it could be the thin line. help me
Aug 1, 2008 at 11:22 AM
MASTERTECHTIM
  • 4,750 POSTS
help is on the way. using a tubing cutter, cut out the piece that is leaking and then install a rubber hose (power steering return hose) and use 2 small clamps on each side of newly installed rubber hose, make sure not to kink the hose. thats it
Aug 1, 2008 at 11:33 AM
