2003 Chevy Impala Intermittent heating
51,000 MILES • 6 CYL • 2WD • AUTOMATIC
MBB219
Hi. My car has intermittent heat. I have not noticed a pattern of when it blows warm and when it does not. I do not smell anti-freeze in the car and the rug on the passenger side has remained dry. Is it possible that the thermostat is going out? What else should I look at? Thanks for your help!
Nov 13, 2008 at 2:18 PM
RHALL77
  • 3,361 POSTS
possible thermostat. are you sure its full of coolant. do you have dual zone heating in it
Nov 14, 2008 at 4:13 AM
MBB219
Thanks for your reply. I will check the coolant level.
Yes, it does have dual zone heating. It is the manual/slide type.
[quote:fcc8ecaa9e="rhall77"]possible thermostat. are you sure its full of coolant. do you have dual zone heating in it[/quote:fcc8ecaa9e]
Nov 15, 2008 at 1:55 AM
RHALL77
  • 3,361 POSTS
does it heat ok on the other side
Nov 17, 2008 at 8:58 AM
