How do I get the key to relearn itself?
TIGERLILY73
I have a 2003 chevy Impala that I bought used a little over a month ago. It does have a security system built in it....However the key dont work. The transmitter is working. The dealership said the key needs to relearn it self...How do I do this? Can you please give complete instructions on how to do this?
Thank you kindly for your time and consideration in this matter....
Jul 2, 2009 at 5:15 AM
RENAUDTN
  • 636 POSTS
Here is the procedure to reset the GM Passlock system:
Turn ON the ignition, with the engine OFF.
Attempt to start the engine, then release the key to ON (vehicle will not start).
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
Turn OFF the ignition, and wait 5 seconds.
The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
(note: Sometime you have to repeat this procedure three times total)
Important
The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Mar 13, 2021 at 2:33 AM
SENIOR35
I have a 2003 chevy impala got new key from chevy car was saying security now after 30 min of key in ignition car still doesn't start but not saying security anymore how do you fix this issue
  • 55,561 POSTS
If you have a new key it must be programmed by the dealer. Did you give them your VIN number before you picked up the key? Because they can code it before they give it to you.
