2003 Chevy Impala Hesitation After Shifting To Drive
35,000 MILES • 6 CYL • FWD • AUTOMATIC
MUDCAT
My wifes 2003 Impala with the 3.4l auto has developed a problem. Once in a while after backing out of the driveway and shifting to drive there is a hesitation when you give it gas. The engine revs and there is no forward motion. After a second or two something grabs and there is a clunck and you are then able to move forward. The car is just now turning over 35,000 miles. Seems as if its only happening after sitting overnight or longer. Also, after it warms up it seems to not be an issue.
May 9, 2008 at 11:48 AM
RHALL77
  • 3,361 POSTS
have you check your transmission fluid lately to see if it is full or burned. it should be a nice red color if it is ok.
May 12, 2008 at 1:16 AM
MUDCAT
After reading some other posts on here I went ahead and had the trannny fluid changed. Hopefully that will take care of the problem.
May 12, 2008 at 10:16 PM
