2003 Chevy Impala Engines hesitates above 3500 RPM and loos
99,000 MILES • 6 CYL • FWD • AUTOMATIC
RONBEST94
2003 Chevy Impala, 3800 engine, hesitates at 3500 rpm looses power and will not accelerate?
3.8 L engine approx 100,000 miles. Changed fuel filter and fuel pressure is about 48 PSI. If you accelerate the engine while not in gear it will rev to approx 3500-3800 RPM then start to hesitate and shutter and will decelerate to below 3000RPM and as you continue push on gas pedal it continues to loose power. If driving the vehicle it runs till about 30 MPH then starts to loose power and will not accelerate. We did get 2 codes P0301 and P0502. These were not consistently showing. The engine idles fine with no missing and runs fine till about 3500 RPM and then it does not miss just hesitates and looses power.
Any ideas would be greatly appreciated.
Thank you for any help!!
Apr 22, 2009 at 11:50 PM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Apr 23, 2009 at 12:26 AM
