2003 Chevy Impala Engine runs hot at first
25,000 MILES • 6 CYL • FWD • AUTOMATIC
AXEMAN5150
When I first start driving my Impala, the engine heats up real fast. The temperature gauge actually goes past the half way mark. But then the thermostat kicks in and lowers the temp. It does this twice and then seems to be fine. My problem is that it seems to be getting hotter the first time (meaning needle goes farther). What could be causing this?
Feb 25, 2008 at 9:48 AM
  • 75,988 POSTS
For a starter replace the thermostat and check the coolant level if it continues get it block or pressure tested.
Feb 25, 2008 at 10:48 AM
