2003 Chevy Impala Engine Noise
99,000 MILES • 6 CYL • FWD • AUTOMATIC
MAX HUMPHREYS
I am hearing a whinning or loud humming noise that is orginating from under the hood. The local Chevy garage believed it was the fuel pump and replaced it. However the noise is still there. It gets lounder the longer the car is driven through the day and it seems to be in the vacinity of the power steering pump and the alternator area
Can you provide some assistance?
Dec 1, 2008 at 2:03 AM
DOCFIXIT
  • 18,828 POSTS
Check level of power steering fluid, If low that will make a whine
Does noise change pitch with turning of steering wheel? if yes pump is problem.
Does noise change when lights on A/C on then Alt.
FYI fuel pump is in tank
Dec 1, 2008 at 3:46 AM
