2003 Chevy Impala Electrical Failure
160,000 MILES • 6 CYL • FWD • AUTOMATIC
BPLLANO
Sometimes car will not show dash gauges working...car will not start but no panel indicators and A/C does not cool lights & fans etc work ok I just replaced ignition switch assembly completely but did not help
Mar 22, 2008 at 4:41 AM
MERLIN2021
  • 17,250 POSTS
Probably need a new cluster...remove the old one, put the new one in and turn the ignition to on for 10 seconds, then off, and it should work...before this check the cluster fuses in the car and under the hood...
Mar 22, 2008 at 5:18 AM
