I'm guessing the code is one of the following: P0480, P0481, P0482, P0483, P0484, P0485.
You said in your first post that you had your compressor replaced; so I'm assuming your AC works, correct? If so, can you tell me if the fans come on when you turn your AC on (they should within a few seconds)? If they don't come on do the following:
Under the hood, you have two black fuse/relay boxes on the left hand side of the engine compartment (passenger side). The bottom one should have three cooling fan relays in it as well as two cooling fan fuses (25 amp each). Using you user's manual for reference, find the cooling fan fuses and make sure they are good. If so, then check your relays. With engine on and AC on, tap gently with the handle end of a screw driver on the fan cont #1 relay. If the relay is sticky, doing so may " œun-stick' it and turn the fan on. If it does, replace the relay. If it doesn't, turn car off and swap Fan cont #1 and fan cont #3 relays. Turn car back on (AC on) and check for fan operation. If fans work then replace the fan cont #1 relay. If it doesn't, you'll need to use a DVM and a scan tool for more troubleshooting; at this point however you may be better off taking your car to a shop.
Of course this is only relevant if you have one of the codes mentioned. If you can, go back to the part store and ask them for the specific code; it would help clarify things a lot.
Thursday, July 22nd, 2010 AT 11:58 AM
