2003 Chevy Impala CEL - Error Codes
131,000 MILES • 6 CYL • FWD • AUTOMATIC
JCBRUEGG
Currently received the following codes on my Chevy Impala ... would like to get a general idea of the severity of these codes so as to be able to speak with a mechanic and not get completely hosed!
Code 300 - Engine Misfire
Code 401 - Insufficient EGR flow
Code 1811 - Max adapt and long shift
Any help you can give me will be greatly appreciated!
Apr 28, 2009 at 12:16 AM
RHALL77
  • 3,361 POSTS
the 1404 is most likely a reprogram. the p0300 is most likely a plugged injector or a bad plug wire. this may also cause the other code.
Apr 28, 2009 at 1:20 PM
