2003 Chevy Impala a/c
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
HINDESKETCHUP
i have an 03 impala. the driver''s side a/c vents put out warmer air by 15 degrees, while the passenger side works as normal at 55 degrees. recognized the problem as ''hvac side to side temp. difference''? would the problem be fixed by the climate control circuitboard or under the hood?
Jun 24, 2008 at 9:53 AM
MERLIN2021
  • 17,250 POSTS
Try recharging the system, you are low on refrigerant...
Jun 24, 2008 at 11:07 AM
