2003 Chevy Impala
125,575 MILES • 6 CYL • 2WD • AUTOMATIC
BCOLLINS13
my temp gauge keeps floating saying its running hot but when i drive the gauge goes back up. it doesnt smoke or leak tho?
Oct 23, 2010 at 4:04 AM
F4I_GUY
  • 3,302 POSTS
If the vehicle is overheating, the first thing to check is coolant level. If you are low, do a pressure check. You will have a leak somewhere.
Intake manifold gaskets are very common on your vehicle, they don't burn or leak externally most of the time too. Check your oil and level, if the oil is real watery or looks like a milkshake, you got a problem.
Oct 23, 2010 at 10:12 AM
