2003 Chevy Impala
180,500 MILES • 6 CYL • 2WD • AUTOMATIC
ANTHONY WHITE
If tranny goes out adding tranny is too late at this point right? Also why wont my car start up?
Feb 14, 2009 at 3:47 AM
JDL
  • 16,098 POSTS
I don't see anything wrong with replacing the transaxle, if that's the problem. Is the rest of the vehicle ok, engine and body? You might call a garage, see if you can get an estimate on the repair?
If the vehicle cranks good but won't start, you can do some basic tests. Have a helper crank it, while you check for spark at the plugs and go from there.
Feb 14, 2009 at 4:00 AM
