2002 Chevy Impala Wipers
125,000 MILES • 6 CYL • FWD • AUTOMATIC
JSPENCE
The wiper on the passenger side starts to move and then about 30 seconds or less while drive, its drops back down and then moved up a little. continues to move a little and then stops completely. I changed the wipers, but that doesn't help. The left wiper is still not moving now and I think its unsafe. Can you let me know how to fix this?
Jan 13, 2008 at 7:39 AM
MASTERTECHTIM
  • 4,750 POSTS
at the base of the wiper arm where it connects there is a little black cover that is plastic, pry it off and tighten the 13mm nut that has loosened. also check drivers nut for tightness, they loosen up all the time. i hope this helps.
Jan 13, 2008 at 7:45 AM
JSPENCE
[quote:93486f7fce="mastertechtim"]at the base of the wiper arm where it connects there is a little black cover that is plastic, pry it off and tighten the 13mm nut that has loosened. also check drivers nut for tightness, they loosen up all the time. i hope this helps.[/quote:93486f7fce]
Thanks for the advise. I do have one other question. Where is the drivers nut located?
Thanks
Jan 13, 2008 at 8:08 AM
MASTERTECHTIM
  • 4,750 POSTS
its also at the base of the drivers side wiper arm.
Jan 13, 2008 at 9:21 AM
