2002 Chevy Impala Windshield washer
58,000 MILES • 6 CYL • FWD • AUTOMATIC
POOLDUDE
Wipers run normally both in the wiper mode and the washer mode. However the washers themselves will not come on. I removed the washer pump and tested it, it runs normally when wired direct to the battery.
Sep 27, 2008 at 12:41 AM
BLACKOP555
  • 10,386 POSTS
check to see if you are getting signal/voltage to the washer pump when switch is pressed to spray fluid.
Sep 27, 2008 at 2:55 AM
POOLDUDE
I tested the voltage at the pump. 12 volts, but not continuous. It seems to come and go. ground tested good.
Sep 27, 2008 at 12:45 PM
