2002 Chevy Impala Traction Control System
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHIE37
My TRACTION ACTIVE message light comes on for no apparent reason. It only occurs when I start moving slowly from a fully stopped position and turning right, such as pulling out of a spot in a parking lot.
Any ideas what is causing this? Thanks.
Apr 21, 2009 at 12:21 PM
JYOUNG2005
was wondering if you had any luck with the problem, or if you did find out what it was. i have a 04 impala that is doing the same thing. thanks for any info.
May 6, 2009 at 9:31 PM
RICHIE37
The second Chevy repair shop I went to found the problem. it was caused by loose wires leading to the traction control sensor on the right front wheel. They reconnected the wires and everything is fine now.
May 8, 2009 at 9:33 AM
