engine coolant temperature sensor
104,803 MILES • 6 CYL • 2WD • AUTOMATIC
KEY KEY
where is the coolant sensor located on the car
Oct 1, 2008 at 2:49 PM
IMPALASS
  • 3,112 POSTS
There is also a Tech Bulletin out on if the light always stays on - if this is doing that you might get the bulletin from the dealer. Your car may throw a DTC code if this is bad. You might run by Auto Zone and let them pull the codes for free.
https://images.2carpros.com/forum/automotive_pictures/248015_2002_Impala_Coolant_Sensor_1.jpg
Mar 2, 2019 at 7:22 AM
