Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Impala
Engine Cooling
Coolant Temperature Sensor
engine coolant temperature sensor
2002 CHEVROLET IMPALA
104,803 MILES • 6 CYL • 2WD • AUTOMATIC
KEY KEY
MEMBER
1 POST
where is the coolant sensor located on the car
Oct 1, 2008 at 2:49 PM
IMPALASS
Experienced Mechanic
There is also a Tech Bulletin out on if the light always stays on - if this is doing that you might get the bulletin from the dealer. Your car may throw a DTC code if this is bad. You might run by Auto Zone and let them pull the codes for free.
Mar 2, 2019 at 7:22 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
