2002 Chevy Impala Stalling
170,000 MILES • 6 CYL • FWD • AUTOMATIC
JENKINM
Engine heads and wires were replaced, new compressor, new radiator, new fuel pump 7 months ago or less, new fuel filter, new fans, and new thermostat. Car wants to stall. when at a stop light and begin to accellerate car puts and shakes as if it were going to stall, but eventually will pick up speed, but after I move from 0 to 20 then 20 to 30, after it is above thirty, car is fine. Engine purrs like a kitten. Is this a bad fuel pump. I had the engine tested at autozone and they said that I need a fan relay switch replaced. Will this cause this problem or is it related to the fuel pump or injectors?
Dec 15, 2008 at 2:40 PM
  • 110,248 POSTS
Hi:
I don't think the fan relay is going to fix the problem. You can have the fuel pump pressure tested, but I think a bad fuel pump would cause more top end speed problems. I would start by looking for vacuum leaks.
Let me know what you find.
Dec 16, 2008 at 6:24 AM
