2002 Chevy Impala Sliding
90,000 MILES • 6 CYL • FWD • AUTOMATIC
PSMARSH
I have an 02 Impala that is drifting to the right when I drive around a left hand corner that is rough. It also slides to the right when driving down a rough, straight road. The rear passenger tire has wear on the outside but not all the way around. What is causing this?
Jun 23, 2008 at 2:46 PM
RHALL77
  • 3,361 POSTS
when was the last time you had the front end check and aligned
Jun 25, 2008 at 1:02 AM
PSMARSH
I had the front end checked and aligned last month. This is happening on the rear of the car.
Jun 25, 2008 at 3:09 AM
RHALL77
  • 3,361 POSTS
did you check and see if there is any broken parts in the rear. maybe a bad belt in a tire
Jun 25, 2008 at 3:37 AM
PSMARSH
I recently replaced the tire and wheel. I am still having the same problem.
Jul 2, 2008 at 2:57 AM
