2002 Chevy Impala service traction control
82,350 MILES • 6 CYL • FWD • AUTOMATIC
HOKIEFORLIFE
message pop ups saying service traction control
how much should it cost and is this something that you can do on your own
May 16, 2009 at 2:36 AM
MMPRINCE4000
  • 8,548 POSTS
First you have to find out what's wrong. You would need a chassis scanner to scan the error codes in ABS/Traction control module.
Could be as simple as the loose/broken wheel sensor, or the traction control module.
Get the diagnosis first, generally these codes have to be scanned by dealer or competent garage. Once you know the problem you can deciede on a course of action.
May 16, 2009 at 2:43 AM
