2002 Chevy Impala Problem Low Beams Not Turning On
185,000 MILES • 6 CYL • FWD • AUTOMATIC
JACKSONB
Low beam lights will not turn on until the car is warm.
This happens when the car is cold or its very wet.
The light sensor not turning light on at night until car is warm.
When its warm the car operates normally.
The lens looks cloudy inside. In the past clicked on the high beam to to reset low beam light. Is it a switch problem or sensor? The problem is getting worse.
Mar 18, 2009 at 9:32 AM
RHALL77
  • 3,361 POSTS
it could be a switch problem or even a body control module problem. have the BCM scanned for trouble codes and let me know what you find out
Mar 19, 2009 at 1:40 AM
