2002 Chevy Impala Power Window Motor
2002 CHEVROLET IMPALA
HNRUSSO
2002 Chevy Impala 6 cyl Manual 89,000 miles
There is a problem with the driver's side with the power window motor and I am trying to fix it but can't figure out how to get the door panel out. I need the direction of how to do this. Thank You.
Apr 24, 2009 at 9:48 AM
  • 110,194 POSTS
There should be screws holding the handel on, and they are along the bottom of the door panel. After removing all screws is to pull the clips holding the panel to the door. They should just pop off for you.
May 4, 2009 at 11:07 AM
