2002 Chevy Impala pcv valve cover
112,000 MILES • 6 CYL • FWD • AUTOMATIC
JTRAYZ4
Broke pcv valve cover when trying to replace old pcv valve. Cover has two snaps on it witch hold cover flush over pcv vave. One of the snaps broke which is causing the cover not to sit flush so the intake is sucking air and causing car to run extremely rough. This cover also has a plug in. On the impala 3.8l this is located on the left side of the intake when facing the car. Trying to find the name of this part.
Apr 30, 2008 at 4:59 PM
RHALL77
  • 3,361 POSTS
go to your local dealer, they can pull a picture up for you to look at and order what you need
May 2, 2008 at 2:18 AM
